Old 10-22-2020, 11:27 AM   #344 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Binge drinking diagnosis
^ Oh stop it.
By chance, I discovered the conditions that cause the most oil consumption in this car: high engine vacuum.
There's one long-ish hill I regularly go down in 3rd gear, in fuel cut mode. I happened to glance in the rearview mirror and saw a cloud of smoke just when I got back on the gas (combustion re-commenced).
I even heard the engine ping briefly when combustion re-started ... that's gotta be a fair amount of oil in the cylinders to make it ping. The tail pipe is also oily inside.
I repeated the test on another hill and saw/heard the same result.
So... rings or valve seals?
