Old 10-22-2020, 11:31 AM   #157 (permalink)
sgtlethargic
My case is weak and yours is nonexistent.
Your case is based on the simplistic analysis "There are more wildfires in CA than NM." The NM map shows the fires are in the mountains. I bet there are more mountains in CA than NM. More mountains = more wildfires.
Similarly, much of CA's air quality problems stem from the fact that it has a large population and a large economy.
You also said "NM does it right." Let's hear what NM is doing that's made the supposed difference.
