Old 09-25-2008, 06:54 PM   #6 (permalink)
aerohead
Originally Posted by Randy_the_Hack View Post
OK... so here's an obtuse way to think about aerodynamics.
On my truck (Chevy Silverado w/Duramax diesel), it has been discovered that the stock air intake, especially where the incoming air makes the final 12-18 inches into the turbocharger, is quite restrictive. This discovery, and the discovery that in later years GM re-engineered the turbo mouthpiece to be much less restrictive (so much so that mileage, power, and engine temps are all noticeably affected - all to the positive), has all of my diesel brethren scrambling to modify their trucks - OK... I did too.
The difference is startling, especially under acceleration, towing, etc. At highway speeds, unless you're towing, the turbo clearly has all the air it needs as boost is 2-5 psi; under load, it's not uncommon to see it in the 24-30 psi, which is where you really notice the difference with this mod.
Now my questions. How would one quantify the optimal solution? Realizing that you have to pull air through a filter, and given a predictable turbo flow rate (none of which I can personally quantify ), I'm wondering how one would go about validating/verifying a solution.
For example, all of these intake systems have an accordion-like rubber section that attach both to the filter box and the rigid pieces of the intake which leads to the turbo (it allows you to open up the filter box to change the filter). Does the accordion significantly disrupt airflow? Would it be measurable? If the accordion isn't straight, would that affect anything?
Then there's this other guy out there who claims that for an optimal solution, you must profile the interior of the air intake system and dimple it like the surface of a golf ball... and he claims the solution he sells has this feature. Is this primarily theoretical, real but hard to imagine it would be noticed, all hooey, or [fill-in-the-blank]?
I'd be interested to hear your thoughts... BTW, here are some pics to demonstrate the differences in the turbo mouthpiece alone - the smaller one is the stock mp from the LLY engine; the larger one is from the next generation LBZ engine.
This is the turbo side end of the mp:
Randy,the only thing I can think to do for quantifying whats going on,is to add some static pressure taps before and after the components,and attach a u-tube or inclined manometer,or Magnehelic pressure gauge,and actually measure the pressure differentials,before and after the mods.This is what tuners will do with their flow-benches,and you can "read" the results directly.If you have a W.W.Grainger in your area,they'll have everything you'll need.---------------- As to the accordian snorkel hose.I don't think it impacts flow resistance at all.And with respect to the dimpling of the interior of the ductwork I would be very suspicious.I was an HVAC techie kind of engineer doing air balance all over the country,and my recollection is that,as with our cars,ductwork,even as small as your diesel's intake,is operating in a high Reynold's Number environment,with turbulent boundary layer,and dimpling would not improve on that.After passing the compressor section of the turbo,it wouldn't matter what had happened to the air before it got there.
