Old 10-24-2020, 05:16 PM   #158 (permalink)
M_a_t_t
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
I did some pressure testing for the separation edges I've had on for awhile. My pitot tube mount wasn't the best and would rotate a little bit so I think I need to modify it and re-test before drawing any conclusions. Possibly use a different road too. Speed limit was 45, I did 50 MPH.
My mount:
I used a holesaw to drill a hole in the broken bumper cover. I thought there was going to be a foam core, but it was actually hollow. Initially the pole was a tight fit, but after driving for a few miles it loosened up. I used some duct tape to hold it in place, which worked fairly well.
On the end of the pole is this. A coiled up coat hanger plus the pitot tube held on with some heat shrink. It was a tight fit over the pole and then I used some electrical tape to secure it even better.
I tested in the 4 spots shown here (tail lights and bumper). Units were converted from inches of water.
Modified light: -27.4 Pa (-24.9 Pa & -29.9)
Stock light: -29.85 Pa (-39.8 Pa & -19.9 Pa)
Modified bumper: -31.1 Pa (-34.8 Pa & -27.37 Pa)
Stock bumper: -34.85 (-47.3 Pa & -22.39 Pa)
I could see the mount rotate (not much, maybe 10* or so) as I drove so I know that was messing with the readings. Not an oscillation, just a change in direction. Probably because of the reverse in direction and therefor crosswind side.
So initially we have 8% lower on the lights and 11% on the bumper. I think I can say the separation edges works, but need to work on the mount to say how much with any confidence.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
