Old 10-31-2020, 12:24 PM   #39 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
First, second, fifth.
...is how I drove my small displacement cars. Ie Miata. You could get up to any legal speed in 2nd, so I would use it to get to speed ASAP and then straight to 5th for economy, and because I didn't need to accelerate any more.
Couldn't skip more than one gear in the 'metro, mind you.
First, third, sixth.
...is how I drive my Z. The close gear ratios and big engine make using all the gears pointless, unless you're trying to have fun. Feels like you're driving a normal 4 cylinder car, if you shift like that at lower RPMs.
The idea, from an economy stand point, is to keep the engine under heavy load as much as possible.
There engine/trans doesn't care what gear you put it in, unless you bog down the engine, or end up over-revving it while down-shifting. Drive how you want.
