Thread: My first XFi
Old 10-31-2020, 04:21 PM   #16 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
I'd put the logo in the front corner of the door. You technically can mask off the ghost, then spray the dip, and peal the mask off while the dip is still wet and it should leave a white ghost of factory paint under. You can do multiple coats that are mostly dry, but that last coat needs to pull the mask while still wet.
The Following User Says Thank You to Hersbird For This Useful Post:
freebeard (10-31-2020)
