Old 11-02-2020, 09:16 AM   #12 (permalink)
M_a_t_t
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Back on topic, I would think that like positive pressures, negative pressures take energy to create and therefore the smaller the deviation from neutral the better.
Then again, we want to establish attachment at the bow/front so that we can maintain a resemblance of attachment along the aft body, right?
That's all going to take energy, question is, what is the magic ratio for energy optimization?
The path to least resistance.
I think it's mostly placement/location on the car. Negative pressure with a forward component is a good use of the energy as it is pulling the car forward. You can cancel the upward component of the negative pressure by increasing downforce somehow (belly pan maybe?). I think you have to look at it as an overall lift though, so if you have neutral lift/downforce then you would only have the forward component. Since I don't think it is possible to have a neutral pressure on very much surface area of the car I think that is the best you can try to accomplish.
That is mostly just my thoughts, not based on anything necessarily.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
