11-02-2020, 07:16 AM
#11 (permalink)
Originally Posted by Charlie Cheap
The LH-6 .....Maybe that is why I owned it 27 years.
My first car was a 1966 Mustang coupe, automatic with a Sprint Six.
Owned from spring of 1979 to fall of 1982, more bondo and fiberglass than I want to think about.
Your photo however brings back fond memories.
Back on topic, I would think that like positive pressures, negative pressures take energy to create and therefore the smaller the deviation from neutral the better.
Then again, we want to establish attachment at the bow/front so that we can maintain a resemblance of attachment along the aft body, right?
That's all going to take energy, question is, what is the magic ratio for energy optimization?
The path to least resistance.
11-02-2020, 09:16 AM
#12 (permalink)
マット
I think it's mostly placement/location on the car. Negative pressure with a forward component is a good use of the energy as it is pulling the car forward. You can cancel the upward component of the negative pressure by increasing downforce somehow (belly pan maybe?). I think you have to look at it as an overall lift though, so if you have neutral lift/downforce then you would only have the forward component. Since I don't think it is possible to have a neutral pressure on very much surface area of the car I think that is the best you can try to accomplish.
That is mostly just my thoughts, not based on anything necessarily.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
11-04-2020, 12:43 PM
#13 (permalink)
magic ratio
The magic ratio is a 'streamlined' body.
There's extreme latitude in the forebody, as this is a location of 'favorable' pressure gradient, with air flowing in the direction of low pressure. No 'magic' radii are necessary. The flow is literally being held in place by the attacking flow.
Once beyond the body's maximum cross-section, flow is 'leeward' of the 'source', in a now unfavorable pressure gradient, moving towards higher pressure, lower momentum, and there's no reason for the flow to remain attached at all, unless the cross-section allows for only a gradual pressure rise ( streamlined) contour, otherwise it will trigger separation, turbulence, low pressure, low base pressure, and higher pressure drag.
Rising out of your seat on a descending roller coaster might serve as an analogy for what the turbulent boundary layer experiences during separation, as the 'downhill' slope becomes so radical, gravitational attraction can't compensate for it any longer. Valve float, with too radical a cam grind overwhelming the valve spring's tension might be another example.
The closer the separation line is to the suction peak near the windshield, the faster the air, lower the pressure, larger the wake, lower the wake ( base ) pressure, and higher the pressure drag.
The energy difference can be calculated directly from the difference in road load power between the sample vehicle, and that of the same vehicle with the minimum drag body.
12-18-2020, 01:37 PM
#14 (permalink)
vortex presence
I think that may be the green flashing light in sequential serial like lines over form as seen in several still photos and videos posted over the years.
If so, I have no memory of it capturing vortex presence.
Frustrating that smoke in wind tunnel testing does little to illuminate vortex presence.
A laser-doppler-anemometry scan of the vehicle's velocity environment, would reveal any anomalies, including vorticity, just as Doppler radar can 'see' clear air turbulence, wind shear, and atmospheric micro-burst down-drafts. Electronics officers aboard nuclear submarines can 'hear' it.
Reason: more data
12-18-2020, 03:09 PM
#15 (permalink)
.tragectory: Line goes down and to the right.
