I had to cover the giant hole I found in the hood when the solar panel flew off...
A little late now, but I'd have turned it around (Faster Backward) and put a gauge or at least a light or two in the back.
I checked my ShopSmith. It has a 7.5" throw. I might have to cut them down individually then gang them together to sand to the final diameter. Then roll the lip with a roller and greased up dolly. That sounds like a better idea than it probably is.
