Thread: MPG aids
Old 11-08-2020, 08:10 AM   #10 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
My Insight came with a lot of instrumentation: Lifetime fuel economy, Trip 1 fuel economy, Trip 2 fuel economy, Current fuel economy (avg since button reset, usually at the start of driving), and an instantaneous readout. There's also a battery charge/assist gauge and battery level.
After changing my engine out, I now have an MPGuino which measures the injector pulses and gives an extremely accurate gallons per hour and MPG figure. I also have a bluetooth connection directly to the ECU which gives anything else I want through an app on my phone. I commonly used it to see degrees of ignition timing, intake and coolant temperature, vacuum, throttle percent, and air fuel ratio (measured vs requested).
