Old 11-08-2020, 11:14 AM   #102 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Wheel and tire weight
We are heading into winter here so I recently switched back to snow tires on steel rims from thin summer tires on alloy rims. I weighed the wheel and tire combinations on a digital bathroom scale and got a rough average weight for each set. The summer tire on the alloy rim was about 36.2 pounds each for a total of 144.8 pounds for all four. The worn winter tire and rim weighed 40.2 pounds each or 160.8 pounds for all four. That is only a difference of 16 pounds of unsprung/rotating weight. I really expected to see more of a difference. I always feel like the car rides more stiffly and seems to accelerate slower with the heavier wheels. Interesting.
I have new studded tires on steel rims that I will use during the worst of winter and brand new LRR tires in the shed waiting to be mounted. I purchased those before COVID hit the US but I am driving much less so I made it through the summer on the old Goodyears. Next spring I will get them mounted and report back on any change in mpg.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
aerohead (11-11-2020)
