Old 11-15-2020, 09:00 PM   #78 (permalink)
freebeard
Are you thinking in front of or behind the stock grille piece?
Does that piece normally block ~30-40% of the opening? Remove and replace with perf metal with the same blockage. Back it with a second piece that can slide 1/2 the distance between the holes. Depending on the hole size it might go from fully unblocked to some % blocked.
It can slide side-to-side or up and down. Manual cable or small electric stepper motor.
ecomodder.com/forum/fossil-fuel-free.html
ecomodder.com/forum/diy-how.html
You can't be wise and in love at the same time. -- Bob Dylan
JacobLeSann (11-16-2020)
