Old 11-16-2020, 09:46 AM   #79 (permalink)
kach22i
I believe the prevailing wisdom on blocks (grilles and open fog-light opening etc..) is that you can do them at front/top surface or behind the opening.
Reason for this is that a pocket of pressurized air forms at such recesses and air flow goes around such pockets of air, similar to a half covered pickup truck bed.
Just say'n if you want to be stealthy with your work and can do it behind it's an option.
I think the reason you see blocks from the street-side is easy to see what you are doing, and zip tie to what's behind it is cosmetically simple.
JacobLeSann (11-16-2020)
