Old 11-19-2020, 05:33 AM   #24 (permalink)
Dizono
Originally Posted by MHR1294 View Post
Any chance, you could show us all how you constructed the tail? Did you keep the standard hatch and cut the inside out to leave a frame to attach the sheet metal too - giving you a hinge and a latch to hold it? I was going to do my tail floor a bit steeper providing I can keep the flow from underneath attached.
We made a steel frame welded to the original tail gate of the car:
We made cuts in the steel bars every 5 to 10 cm's with a grinder and then welded them back together to get the desired curve. We then made paper templates of the aluminium panels, that we formed on the car using metal working hamers and spanners:
So we nailed the panels to the frame while holding them tensioned and that worked surprisingly well. It turned out better the we expected.
Are your wheels discs just held in place by a screw in the centre, the standard hub cap is beneath this?
We welded a bracket to the original steelies:
The we made a hole with thread in the brackets, to mount the aluminum wheel covers with a single bolt.
The Following 4 Users Say Thank You to Dizono For This Useful Post:
Cd (11-19-2020), Leinaad (11-19-2020), MetroMPG (01-19-2021), M_a_t_t (11-19-2020)
