Old 12-01-2020, 02:52 AM   #33 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
I was going by energy equivalent.
Propane is 4.2 lbs per gallon
Gasoline is 116,000 btu per gallon
Propane is 84,250 btu per gallon
11 lb / 4.2 = 2.62 gallons of propane
2.62 / (114,1000/84250) = 1.94 gallons gasoline equivalent.
For whatever reason, that didn't even cross my mind.
On the other hand...I wonder how much efficiency is gained by using a gaseous fuel at partial throttle...you'd have less vacuum to fight, ie less pumping losses. All I have to work off of is when I lent out my dual-fuel generator...they ran it all day and into the night and didn't even use up a 20lb tank. iirc.
