Old 12-01-2020, 03:11 PM   #38 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
It's worth noting, if you still have the computers plugged in on top of the IMA battery, you *may* run into issues where they decide to turn the DC-DC converter off, due to there being an IMA issue. Which in turn will let your 12v battery die. If you ever see the 12v battery light come on, this is the likely cause, and the "fix" is to yank those plugs.
Here's to hoping you can get your IMA gremlins resolved. Otherwise, there's always the arduino bypass, to turn off your CEL and make the car emissions- and inspection-ready.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
MetroMPG (12-02-2020), Stubby79 (12-01-2020)
