Old 12-08-2020, 11:36 AM   #55 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Originally Posted by nemo View Post
Are they the correct plugs for the car?
https://ecomodder.com/forum/showthre...ght-29879.html
i had the idea they were correctly indexed if the proper color code was used.
Correct plugs - as in the same iridium with the same part number written on it, but they are not indexed. There is no A, B or C stamped on the top of them.
Which reminds me, I didn't look at the A, B or C stamped on the head by the spark plug holes. There was a DIY heat shield there, a thin sheet of aluminum, being held on by the coil's bolts. Someone was concerned with heat rising up off the catalytic converter, it seems. Thought it was OE with how well it fit until I noticed the relief cuts made in it, obviously made by hand shears.
Ecky, thanks. I'll start banging on things to see what's rattling one of these days when I'm in/around those areas anyway, or when it starts bugging me enough.
