Old 12-10-2020, 11:37 PM   #12 (permalink)
dayvon
Perry - '98 Honda Civic EX
90 day: 40.45 mpg (US)
What do you plan for supplementing/augmenting battery charging?
Credits to Daox https://ecomodder.com/forum/member-daox.html
Daox had the idea to: use a "smallish" ~15 V lithium pack and connect it to the starter battery (either directly or using the cars 12v plug). While maintaining enough voltage, the pack should be able to keep system voltage above that "set by the alternator, thus disabling it." Link below:
https://ecomodder.com/forum/showthre...ete-37923.html
I forget where I remember reading this, but I believe reading that Hondas 5th -or 6th?- VX or HX charging setup operated similarly, but without the extra battery supplement. It's alternator would charge the system when voltage dips below a low threshold and switch off after reaching a high threshold. I don't know how correctly I'm vaguely describing this, but I intend to learn of this systems mechanics and efficacy. If I can have/do this for my application, then this instead.
The Following User Says Thank You to dayvon For This Useful Post:
aerohead (12-11-2020)
