Old 12-11-2020, 10:28 AM   #23 (permalink)
Piotrsko
Not only will I make you think, I will challenge your thoughts. Riposte.
Umm your flow is wrong. The back flow through the circuits is through the diode. I don't recall mosfets conducting in reverse bias. Same deal with IGBTs which is why you need 2 to do AC. So there is no voltage applied to the corresponding gate and the mosfet is not on. You said so yourself right after "but wait".
