Cross member /cross tube
The cross tube that supports the steering wheel column from within the dash. Did you remove this on this vehicle??. I notice various auto manufactures use the cross tube to support steer wheel column.
Would be curious if some different lighter material may be used. However getting the steering column support right and geometry right would be a concern. Thanks
