Decided to get a little bit more done with the dash deletion sub-project. Stripped the climate control assembly down. I've been using the levers on the ducting to control the output so all I need is the blower motor switch. The assembly wasn't included in the "as removed" weight so this isn't going to contribute to my goal there.
Started at 1 lb 1.55 oz (1.097 lbs or 497.6 grams)
Removed the blower motor switch. I could probably save a few more grams by de-soldering the wires and socket for the bulb and the defrost switch. Ended up with 3.65 oz (.228 lbs or 103.5 g) for a savings of .87 lbs (394.6 g)
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
