Old 12-14-2020, 08:49 PM   #185 (permalink)
cRiPpLe_rOoStEr
Originally Posted by M_a_t_t View Post
Maybe even getting rid of the bends in the bar could save a little bit of weight since it will use a little bit shorter piece to cross the span.
IIRC this often happens in those JDM second-hand cars exported to Paraguay while they're converted from RHD to LHD.
I've been thinking about getting an aftermarket steering wheel so if I do that I can ditch both airbags and lose ~13-16lbs (just a guess)
Are you also counting the removal of the sensors that trigger the airbag?
