Old 12-15-2020, 03:24 PM   #16 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
The cranks have counterweights, them roundy things at the ends of the journal.
There's even a limit as to how much con rod weight you can use, and I have had shops drill the cranks when I got I beam rods. I agree, they dont have dampners because the crank is short and beefy so doesn't flex much.
Peformance aftermarket VW cranks have counterweights. But the stock ones do not.
Crankshaft length is shared by a V-4. The boxer [four] has an inherent balance compared to a V or inline arrangement.
Good point from you both!
You can ignore the rest, it's just me bragging.
I did balanced the heck out of my Type 1 dual port engine when I rebuilt it. I had the crank (stock without counterweights) dynamically balanced along with the flywheel, clutch plate assembly and even the pulley. Then I took and got all the pistons, pins and bearings within a fraction of a gram of each other and also suspended the connecting rods over two scales so I could balance each rod end so all the small ends and all the big ends also weighed exactly the same.
I've seen the same engine in a friend's Super Beetle bounce all over the place just idling. My engine ran smooth as butter, which is one reason the guy who bought it was so impressed.
The Following 2 Users Say Thank You to Isaac Zachary For This Useful Post:
Ecky (12-15-2020), freebeard (12-15-2020)
