Old 12-17-2020, 10:40 AM   #19 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
I don't remember when it was the last time I saw a harmonic dampener. Even some 3-cyl engines are kept deliberately unbalanced from the factory.
Must be a small engine thing? Everything for the most part has harmonic balancers or internal balance shafts here in the USA.
In Toyota fashion the Prius has a harmonic balancer with belt grooves in it and it doesn't even have an accessory drive. Probably because it already existed and worked.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
Ecky (12-17-2020)
