So, I decided to take a look at the diffuser "
reference" Julian Edgar posted here.
In the the very first part of the explanation of lift (downforce) it says:
The air passing under the wing has further to travel than the air passing over the top surface. This causes the air under the wing to accelerate, resulting in a drop in air pressure, this creates a difference in pressure between the upper and lower surfaces.
To which I need only let JulianEdgar himself come to the apparently obvious conclusions:
I guess this is why so much misinformation has been disseminated here.
To state the bleeding obvious - it is wrong information that you are spreading. Outright wrong. No nuance here - wrong.
How they say a diffuser *wing* works is simply quite wrong. So what do you do about it?
Am I doing this right?
Here is an
excellent video starting at the explanation why "The air passing under the wing has further to travel" is not a correct explanation of lift which, in this explanation, is just the inverse of downforce.
If you want to see a really in depth and fascinating debunking of common aerodynamic myths,
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
