Old 12-28-2020, 08:46 PM   #61 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Originally Posted by Vman455 View Post
And then you reached this conclusion:
I didn't mean that as a conclusion. Should have added an /s. It was meant to jokingly prove a point about semantics and pedantry. I'm poking fun in both directions. A fixed template that claims to solve all problems is obviously not practical or efficacious (not that I ever thought the template was) but output from applied knowledge meant to modify a vehicle can be a template.
(Also, the "context from the experts" you posted refers to the Ahmed body and SAE body, not the DrivAer models. It isn't clear in your subsequent posts that you understood that).
I did and I'm glad the piece was posted.
But the first quote is a caution against using simple bodies to predict flow over a real car because the flow around them is too complex to predict with something like a template. For example, just because a researcher tested a cylindrical body and found that it had lowest drag with a 22-degree taper doesn't mean that a 22-degree taper will give lowest drag on any car.
I agree. I have personally never expected "thee holy template" to do anything more than exemplify one possible low drag shape and, in the absence of something better, ie: CFD and an accurate model of my personal vehicle, to give one a very basic principal shape to keep in your head. At the time I was active, I understood the 22 degree taper to be a rough guide for mods which would then require tuft testing and evidence of mpg improvement.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
