Old 12-29-2020, 02:40 PM   #15 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I have a couple of questions about a couple of possible issues with throttle stop testing. In order for this type of testing to be reasonably accurate, both the environment of the test location as well as engine power output would have to be constant over the full period of testing.
As I understand it, fuel injected cars change the air/fuel ratios pretty much constantly with changes in engine temperature, etc and the Insight, in particular, has it's lean burn mode that happens automatically. This seems to make a big difference in throttle position/speed as I have noticed and I think MetroMpg noted as well.
Are you controlling for this in your tests?
The other is atmospheric effects which can change engine power significantly, which I'm sure you are aware of. Barometric pressure can change dramatically in the space of a few hours in extreme cases, so one should probably keep tabs on that especially if tests are done on different days or times of year. Humidity also plays a role in engine power.
Have you taken these into account?
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
The Following User Says Thank You to orange4boy For This Useful Post:
aerohead (12-29-2020)
