Old 12-31-2020, 12:52 PM   #5 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
If we can reduce lift and reduce drag simultaneously then I am all for it. I do care about lift. Most of the time I drive below the speed limit for optimum mpg. However, there are times when I drive faster here in the wide open, sparcely populated rural west, and like Kachi said, I also drive this car in terribly slick winter road conditions.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
aerohead (01-06-2021)
