Old 01-01-2021, 09:47 AM   #9 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Best I can tell, all of the Honda engines I've worked on use ignition to fine-control idle. The pre-drive-by-wire vehicles had an idle valve that let in more air when cold, whereas the post-DBW vehicles would simply crack the throttle plate, but both retard ignition significantly at idle.
Take the K24 I'm using from an Acura TSX - it's ~8 years newer but functions the same way as the Insight stock engine in this regard, or our Fit. At idle I'm generally seeing ~5-7° ignition advance. When I flip the headlights on or toggle the A/C it jumps maybe as much as 6-8 additional degrees momentarily to hold the idle perfectly steady, and then levels out at 1-2° more advance to hold the same idle speed. Touch the throttle lightly and it's instantly at ~24° advance, which is ballpark for MBT at that load and RPM.
Here's one of the timing tables my car uses, for example:
Idle timing uses separate logic, and there are different tables for every 10 degrees of intake cam advance, and separate tables for all of these in and out of VTEC.
Isaac Zachary (01-01-2021)
