Old 01-01-2021, 03:38 PM   #4 (permalink)
Dala
Originally Posted by jakobnev View Post
What is the song in the video? (I need to hear the rest of it)
Corneria - Qumu
So, does the i3 base its state of charge off of voltage? That is, simply adding more modules to it (in parallel) works?
I know with most hybrids based on nickel chemistries, doubling the amp hours doesn't increase the usable capacity because the computers have to track state of charge through an amp meter and a computer model of battery capacity, since voltage isn't an indicator of state of charge.
No, same amount of modules, just more power dense. 18.2kWh -> 37.9kWh would be a better way to put it instead of 60-120Ah. Weight was increased with 75kg with this upgrade.
The Following User Says Thank You to Dala For This Useful Post:
jakobnev (01-01-2021)
