Old 01-01-2021, 05:58 PM   #4 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 50.97 mpg (US)
Bad news for US (North America)
I followed the original Throttle Stop thread and assumed it would not work on the TDI since it is both drive-by-wire and turbocharged. I saw this thread and hoped it might give us another option besides A-B-A that Darrin has suggested for years. Alas, I tried it today without success.
I had the car mostly warmed up on a flat, straight road, at 70 mph, 16 degrees F with zero wind and speed and elevation measured by a Garmin on the dash. First, the Throttle Position Sensor on the ScanGuage (TPS) was useless as it just read 95 all the time unless I really stood on the throttle. I tried Load (LOD) but it was all over the place even with my right foot braced tightly on the footwell. I finally tried Gallons Per Hour (GPH) and was able to hold a fairly steady 1.66 @ 70 mph. However the windows up or down did not show a consistent difference in top speed.
I would say that for the most common small diesels in North America (Volkswagen Audi Group TDI) Throttle Stop testing may not be a viable option.
If anyone would like more info about A-B-A testing on my Golf TDI check out my Heresy thread.
EDIT: I just read a note from Julian that suggested that the test distance needed to be over the course of a kilometer. I may have to repeat the test under better conditions in the future. If anyone is attempting this with the TDI I still suggest bracing your right foot and using GPH on the ScanGuage
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
JulianEdgar (01-01-2021)
