Old 01-06-2021, 05:52 PM   #18 (permalink)
JulianEdgar
1. When imagining pressures at the front of the car I can successfully imagine the air being still and the car slamming into the air molecules.
That's actually not a good way of thinking about it, because quite a few front-facing surfaces develop thrust (eg leading edge of bonnet/hood, top of windscreen). Instead it's much better to think of what speed the air is going at. The slower it is going, the higher the pressure; the faster it is going, the lower the pressure.
2. When imagining drag pulling back on the moving body/car parasitic, vortexes, and low pressure described in opening post of this thread.
Yes, but don't forget that attached flow on the rear parts of the car can cause drag as well.
