Old 01-08-2021, 02:43 PM   #13 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I tried using the mountain sunset button. I can only see a square. Is this because I use Apple?
From this thread.
https://ecomodder.com/forum/showthre...ats-13669.html
FWIW, Julian has tested front tire spats on an early Prius (his version was more like “canoe boat tail spats” at page 6) and found increased lift, instability at speed and reduced mpg.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
