Old 01-08-2021, 05:30 PM   #11 (permalink)
JulianEdgar
You'll want to navigate to the other Figure and do the drafting. Once you've created the image, you can do the overlay, and compare.
No, what I want to see, and if you are right there should be chapter and verse on it, is a section in any aerodynamics textbook that applies a template as has been so often been encouraged here. Viz:
- Show where there is separated and attached flow on existing cars
- Guide the shape of rear extensions
- Show how rear spoilers on sedans should be positioned and shaped
- Allow the assessment of the ‘aerodynamic purity’ of cars
There is no such coverage in any textbook, as you have made clear with the diagrams you are referencing that have zero to do with a template.
It's all just your rather odd theory. As I have said before, it's just a crying shame that so many people were sucked into it for so long.
