Originally Posted by aerohead
1) I've given you a textbook on aerodynamics with the 'template' strenuously presented. You'll have to connect the dots which are screaming off the pages. You simply need to do the work which will then give the visual reference. Your tire analogy is asinine.
2) I've provided all the information necessary.
3) I've provided a list. Obtain the technical images as I have, and do the overlay comparisons.
4) I've addressed this adequately. I've provided the necessary materials. I can't understand them for you. It's not my problem. EcoModder.com members don't require your imprimatur to set land speed records, fuel economy records, or distance records. We don't need the imprimatur of any of your select panel of experts either.
It's just amazing how you're the only person in the world who has joined the dots. Not even the author of the book you cite was able to do that, eh?
So, take your pick. Aerohead has seen something that the world's best aerodynamicists haven't - or Aerohead is quite wrong.
I am always very happy to be guided by the world's best aerodynamicists.
