Thread: A pillar guides
Old 01-12-2021, 12:27 PM   #74 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Back on topic?
Originally Posted by JulianEdgar View Post
Today I have found two papers that cover turning vanes.
One paper showed that aerofoil sections are much better than flat plates (what I'd found in my testing) and the other showed that really good gains can be made on older cars' A-pillars by the use of turning vanes (which also supports what my tuft testing showed).
So I'd like to fit them to my Insight, but the same old problem remains. No matter how hard I look, I cannot find an aerofoil-shaped aluminum or plastic extrusion that I can easily buy by the metre that's roughly the right size.
If it is not possible to weld 2 sections together to make the length needed, I have had surprisingly good results with J-B Weld, a very strong epoxy. It would be best to add some dowels in the hollow cavities for alignment and support.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
aerohead (01-15-2021)
