Old 01-13-2021, 04:38 PM   #25 (permalink)
JulianEdgar
By making holes in the panel you're destroying some of the facility for pressure recovery, which is the underlying premise for the box-cavity's performance. It needs to be as air-tight as you can make it.
If it were just pressure recovery caused by longer flows down the sides/top, it wouldn't need to be a cavity would it?
aerohead (01-13-2021)
