Old 02-01-2021, 04:23 PM   #36 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Tried taking it apart, no dice. Had to buy a 27mm socket to get the nut off the pulley. Odd size.
22mm keyed front shaft:
14/12mm tail shaft:
Thought I'd lost the key...spent 10 minutes looking for it on the floor, only to find it hiding on my bench under the motor.
No photo, but good to note...the 4 big bolts clamping the two halfs of the unit together are in a lovely square, making it 6" square in the middle...nice and tidy for use as mounting points.
And on a side note, I had a regular alternator pulley on my bench, and it just happened to be the same 17mm that both my treadmill motors use. Nice fit:
Can probably turn it around and make it closer to the body of the motor.
ID:	30095   Click image for larger version
ID:	30096   Click image for larger version
ID:	30097   Click image for larger version
ID:	30098   Click image for larger version
