Old 02-20-2021, 09:42 AM   #25 (permalink)
Piotrsko
Why do you need to repoint the antenna? Nothing I saw said that was necessary. The typical aperture is a couple of degrees wide and if you design the backplane correctly maybe as high as 10 degrees. Yeah you'll lose a couple db on the edges and gain some in the sweet spot but REALLY????
Maybe you need 100% comm while the balance of the network gets installed
Wifi router?
