Old 02-21-2021, 06:40 PM   #376 (permalink)
Should be biking
I haven’t pushed the range too much. Guessing it’s around 20miles in 45F weather with full boost. Reducing the power mode makes a big difference obviously.
Ride isn’t too bad. For what it’s worth, the front fork is carbon fiber. The 2.1” tires help a lot.
There is a torque sensor and it ramps in the torque so it doesn’t feel like it’s trying to pull the bike out from under you. If you hold down the plus button on the display it will go 12mph without pedaling. But that feels like a crawl.
The Following User Says Thank You to Should be biking For This Useful Post:
The Toecutter (02-23-2021)
