Old 02-26-2021, 04:43 PM   #17 (permalink)
RustyLugNut
That is my point.
That's what they do:
Why take the extra steps (as well as energy ) to oligomerize into naphtha and paraffin? The next step would be to form gasoline or diesel. More energy and time! Just use the butanol as is! Use the di-methyl-ether (DME) as is!
Both butanol and DME have improved octane allowing higher compression ratios yielding more efficient engines. Both produce more active radicals in the pre-combustion breakdown allowing greater use of lean burn and exhaust gas re-circulation with less penchant for NOx ( nitrous oxides ) production and UHC (un-burned hydrocarbons ) formation.
