Old 03-02-2021, 12:57 AM   #16 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Isaac Zachary View Post
The goal here would be to make an system that supplies 80% CO2 and 20% O2. The CO2 is an inert gas, just as nitrogen is an inert gas. The goal is NOT to make a highly oxygen enriched intake charge. The goal is NOT to make an extremely low oxygen level intake charge. Just keep it at 20% along with 80% inert gases like CO2.
CO2 is not hard to produce in an internal combustion engine. It's free. It's the product of burning hydrocarbons with oxygen. So is water. So the engine will continuously be supplying more than enough CO2 and water than we'll ever need. The main disadvantage is that it would require substantially more cooling.
Would be quite interesting if you could insert the purified OČ inside the cabin and recover the COČ from it.
The O2 would be the hard stuff to produce. O2 air separators are expensive, and require substantial power. But just like anything, this would start out first as an experiment. The question is, could the benefits of not having to deal with NOx outweigh the efficiency penalty of separating O2 out of the air.
Considering it would probably require more energy than any increase it could lead the engine output to have, it might be as hard to justify as those HHO generators.
