Uhg, that looks terrible. People suck. People suck bad.
Destroying your aeromods without - presumably - even getting it running is just ridiculous.
Almost better if you'd never gotten it back, considering you had to pay to get it back in that condition.
If you decide to try and fix it, you'd probably be better off to see if you could buy a whole steering column with everything on it, including a key, from a junk yard. Should just plug in to the harness under the dash, bolt right on, and not have any gremlins with it. Unless they messed up wiring under the dash too.
If you're going to try hotwiring it, start with a wiring diagram that shows you what color wire is for what. The main power wires ought to be thicker than the rest, unless it uses relays to switch the main power on.
Welp, let us know how we can help. Otherwise good luck!
