Old 03-21-2021, 02:02 PM   #599 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
My TSX is geared stupid. If I put larger diameter tires on (not sure they would fit), I could use this to adjust the speedo.
Thought about installing an RSX final to reduce RPMs.
Even better than the RSX final (unless it's too tall for you), there's a group on Facebook that sells an OEM 4.1 (4.058?) final drive that comes from the Euro Accord, and their prices are very reasonable.
If I could do my build over again, I'd probably use their inexpensive OEM 4.1 with a K20 engine, because aftermarket gears tend to whine.
https://www.facebook.com/theoldschoolcapital
If you need a speedometer correction though, I do have a Dakota Digital converter that I no longer need.
redpoint5 (03-21-2021)
