Old 03-21-2021, 08:26 PM   #602 (permalink)
Ecky
90 day: 89.66 mpg (US)
Honestly, I'm not certain what all is involved in removing the transmission from a TSX. The Insight doesn't have a subframe, so it's a matter of unbolting the transmission and loosening the engine mounts so it sags, then sliding the transmission off. Once it's out, taking the transmission apart isn't hard or very time consuming, except that you need a press to get the CS gears off.
