Old 04-01-2021, 01:44 PM   #11 (permalink)
Xist
I think that I will measure it, add 1/8", make sure that everything is square, nail the corners together, and then saw both pieces at the same time.
Only problem with your nail in place and cut it trick is that you will leave a kerf the width of the saw blade and thus have a gap in your trim in the very corners you are trying to hide the gaps.
An eighth of an inch isn't enough to compensate?
