I have had the car now soon 4 days. So far I have got ~6% better FE
starting point calculation:
https://ecomodder.com/forum/tool-aer...ToStep=40-65-1
Current situation cd at about 0,24:
done mods:
- 195/55r20 tires with BMW i8 wheels. These are 4% taller and increase ride heigth 15mm. Which is bad for FE. Savings 2,3%
- Grill block Savings 1,3%
- Rear suspension arm covers 1,3%
- Front suspension arm covers 0,6%
- Bigger Front tire deflectors 0,5%
Underside is pretty smooth from factory. Only the suspension and wheel areas is where you can make improvements.
Idle energy consumption is 2-2.5kwh when car is warm when outside temps are +4 to +7 celsius. Thats a lot in my mind.
Pictures on my facebook page:
https://www.facebook.com/media/set/?...76628169017686
Weird results in tire pressure tests.Lower pressures gave almost better results. On first tests I have thinked that the warm up takes about 20km, at least then the idle consumptions is around that 2-2,5kwh range. Maybe bearings and oils take little bit longer any experience and better data on EV warmup times?
