04-07-2021, 04:02 PM
#9 (permalink)
My question is do Tilt sensors sense tilt when the car is breaking?
en.wikipedia.org/wiki/Inclinometer#Factors_which_influence_the_use_of_in clinometers
Factors which influence the use of inclinometers
(Overall accuracy varies depending on the type of tilt sensor (or inclinometer) and technology used)
Gravity
Temperature (drift), zero offset, linearity, vibration, shock, cross-axis sensitivity, acceleration/deceleration.
A clear line of sight between the user and the measured point is needed.
A well defined object is required to obtain the maximum precision.
The angle measurement precision and accuracy is limited to slightly better than one arcsec.
Don't Worry Be Happy -- Bobby McFerrin
