Old 10-01-2008, 08:30 PM   #732 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I should also add that you only "need" to adjust the defaults if you are doing simple display of the serial data. If you are writing an actual program to run on a computer or pda/whatnot then you will probably want to manage the correction factors in that application, and can just use the data coming over the serial port as-is. just uncomment the //#define usedefaults true line to prevent it from going into setup.
