Originally Posted by aerohead
* Without the heat flux, we can't anticipate if any of the two original radiators would be adequate to dissipate it, or if the Metro water pump would be adequate for the necessary ( but unknown ) coolant flow rate.
I think you're missing a point.
The metro radiator is the stock radiator for that engine, so yes, it would be sufficient as well as the water pump.
Given the scope of this cite it would be safe to assume we are looking at an econo-box. One that is full of tinkering, so a general idea of what might work is pretty much what I was hoping for.
Edit:
No sense in waiting to post about it. I am really interested in trying to mimic the 911 carrera's radiator setup. I like a bare engine bay, the minimalist look you might say. So I was thinking maybe I could try and use some ducting and tuck the radiator (whatever it might end up being) between the bumper and wheel wells. The stock radiators seem
WAY too big to fit in that area. So I was hoping to do some initial research into what might work. Then when the time comes maybe do some testing. Since it would require dismantling and building a custom setup each time I'd like to get a solid plan down before tearing into it.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
